ramprasadd Tue, 11/04/2008 - 20:31
It supports on all 24+38 ports but only problem with 24 ports is they are designed on shared bus architecture Ex:-1,2,4 ports shares a single bus so overall throughput will be 1gig.Definately, its a constraint when you are using electrical ports as uplink. you need to be selective in choosing the ports.
Use the rating system if you find the reply is useful
