Wirless config with a cisco 881 gsm
Nov 4th, 2008
Hey guys,
Going to order the first of our 881g's today for our spoke sites. Can anyone point me to a good document for configuring the GSM radio interface and so on.
Thanks in advance.
carenas123 Mon, 11/10/2008 - 09:46
The Cisco 881G and 888G ISRs provide a Third Generation (3G) wireless interface for use over Global System for Mobile Communications (GSM) and code division multiple access (CDMA) networks. Its primary application is WAN connectivity as a backup data link for critical data applications. However, the 3G wireless interface can also function as the primary WAN connection. The interface is a 34-mm PCMCIA slot.
