NAC network scanning doesnot work
Answered Question
Nov 4th, 2008
Hello;
I got the nessus plugins from tenable web site and uploaded it to the nac manager then tried to apply the plugins in the plugins setup but i didnot find anything is there any cli or installation proccess i need to perform to has the nessus plugins operating?
Correct Answer by Daniel Laden about 8 years 3 months ago
you will need to extract the contents and build new files smaller than 10MB. Load each one seperately. Maintain the directory structure in the tar'd file.
Overall Rating: 5 (1 ratings)
namnt2604 Wed, 11/05/2008 - 09:03
Could you tell me the size of nessus plugins file you have got from tenable website?
The correct size is about 15 MB! If you have got a file with other size, that means you have got a wrong file! Try again ...
ahmedelfeki Fri, 11/07/2008 - 07:21
There is a file which is 16M of size and when i upload this file there is an error appears that the uploaded nessus plugins is greater than the allowed size so if that is the wrong file where can i get the right file i tried also to register with the command nessus fetch --register it is successfully upload but doesnot operate.
There is also another file with 7.29M of size for nessus plugins but didnot need for registeration it was uploaded successfully but didnot operate.
note:- the nac server model is 3310 and manager is 3350 and the sw version is 4.1.2.1.
Daniel Laden Sat, 11/08/2008 - 10:09
There is a bug in NAC that limits the size of plugins.tar.gz (CSCsq59801). It has been corrected in 4.5, the work-around is to break the file into multiple parts so it does not exceed 10MB.
ahmedelfeki Sun, 11/09/2008 - 06:24
so can i do any thing to increase the size of bug in 4.1.2.1 or if i decreased the plugins file will it operate.
and when i download it through the CLI using linux command nessus fetch --register it is uploaded successfully in the nac but i donot see the nessus plugins in plugin setup.
Correct Answer
Daniel Laden Sun, 11/09/2008 - 11:12
