Warning message
determining current E# of connections before applying limits
Nov 4th, 2008
Where do you pull statistics on the ASA to determine my current teraffic patterns to a DMZ server so I can estimate reasonable values for connection limits?
suschoud Tue, 11/04/2008 - 09:17
  • Gold, 750 points or more
Issue :
sh conn | in x.x.x.x
x.x.x.x--> ip of server
It would give you all the existing connections made to the server.
Issue this several times at different times in a day to find out the meximum connections made to the server.That number can be used as the meximum limit....
Do rate if helpful.
Sushil
