nat'ing
Nov 4th, 2008
i have a pix 506e in front of my network i have several servers in my network, but there are 6 servers that i am concerned about.
is it possable in the pix to put those 6 internal ips in a group and have that group use nating through 1 IP address?
dhananjoy chowdhury Tue, 11/04/2008 - 09:52
  • Silver, 250 points or more
Use policy NAT if you want the servers to go to the Internet with Public IP A.B.C.D,
then if your servers are 10.0.0.101 till 106
access-list 101 permit tcp host 10.0.0.101 any eq 80
access-list 101 permit tcp host 10.0.0.106 any eq 80
static(Inside,Outside) A.B.C.D access-list 101
Also you can create object-group for the Internal Server IP's and use it in the ACL.
Hope this helps
suschoud Tue, 11/04/2008 - 09:54
  • Gold, 750 points or more
Here u go :
Security506E-6.x(config)# nat (inside) 1 1.1.1.1 255.255.255.255
Security506E-6.x(config)# nat (inside) 1 1.1.1.2 255.255.255.255
Security506E-6.x(config)# nat (inside) 1 1.1.1.3 255.255.255.255
Security506E-6.x(config)# nat (inside) 1 1.1.1.4 255.255.255.255
Security506E-6.x(config)# nat (inside) 1 1.1.1.5 255.255.255.255
Security506E-6.x(config)# nat (inside) 1 1.1.1.6 255.255.255.255
Security506E-6.x(config)# global (outside) 1 inter
1.1.1.1---1.1.1.6 will use outside interface ip for natting.
Do rate if helpful.
Sushil
Danny Guillory Jr Tue, 11/04/2008 - 09:58
ok right now my PIX does NOT do any natting at all. all my servers have a manuel IP address mapped to external ip... so i do no think this is complete... just looks like something is missing
