Chris Deren Tue, 11/04/2008 - 09:50
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sure.
Chris
Chris Deren Tue, 11/04/2008 - 10:17
  • Hall of Fame,
Abbriviated dialing is a feature on CM that allows users to dial their personal speed dials entered in the ccmuser page. What you are referring to is essentially global speed dial. The easiest way to accomplish that is to use translation patterns, so in your example you would have a TP with DN #777 that is configured to transform called number to 5554.
HTH,
Chris
ricardorojas123 Tue, 11/04/2008 - 10:37
Thanks, Chris , but there is some document about the configuration of this configuration
