11-04-2008 10:20 AM - edited 03-11-2019 07:07 AM
Would any of you know if the ASA 5500 family support multiple PPTP/L2TP - VPN client connections from inside to outside (i.e. private network to the Internet)?
We currently have a PIX 506E and it doesn't support more than 1 PPTP/L2TP connection at once.
Any input would be usefull.
11-04-2008 10:25 AM
I believe its same with ASA.
Check this
11-04-2008 01:05 PM
I could be wrong, but I seem to remember it's one connection inside-to-outside per outside public IP address (if you static NAT the inside clients that need the connection).
This might get things working for you.
