CCX5: Picking up additional calls from a Queue
Nov 4th, 2008
On Cisco Contact Center Express 5 (Standard) the agents can log in/out and either be ready (or not) through the IP phone.
My question is this. If an agent is on a call, is there a way the agent can pick up another call from the queue to answer?
Thank you!
Overall Rating: 5 (1 ratings)
Chris Deren Tue, 11/04/2008 - 10:42
No there is not. An agent can only be handling one call at a time on the ACD line. I know some systems i.e. I3 allow agents to pick up calls from queue, Cisco like most vendors do not allow that and the agent will be presneted with the next call based on defined routing algorithm such as longest idle, most skilled, etc.
HTH,
Chris
ryabutler Tue, 11/04/2008 - 16:26
I was thinking about that, but hoping I was wrong.
Thanks again Chris!
Anthony Holloway Thu, 11/06/2008 - 19:59
Just to promote conversation...
If you had two extensions on your phone, one ACD, one non-ACD, you could transfer calls from your agent line to you personal line.
This way your agent line is idle, and depending on your CSQ settings, you would be made ready right away, and could take another call on your agent line.
You could even create a macro button to make that transfer happen with one click. Though it would be messy with many agents.
Discuss...
Chris Deren Thu, 11/06/2008 - 20:03
It sure is a workaround but I would strongly suggest against it as it completely defeats the purpose of ACD, as you loose true reporting of these calls. If that's what you are to do you might as well set up hunt groups.
Chris
Anthony Holloway Thu, 11/06/2008 - 20:09
Certainly I was not promoting circumventing the intelligent routing of ACD, but rather promoting problem solving thinking.
