VG248 Gateway connection options?
Nov 4th, 2008
We have a VG248 in place and connected using rj21 amphenol connections to an RJ21 amphenol cable that is punched down on a terminal block. From the terminal block we cross connect two wires per pinout (striped and solid) to other terminal blocks that tie out to each of our floors. We are moving to another office in a few months and I want to know if I have any options with regard to connecting the ports out? I am not sure we will have the terminal blocks that tie out to the new floors and I am wondering if I can maybe use an amphenol that can be patched out instead of cross connecting wires.
Any thoughts, experience, suggestions, would be great?
Thank you.
Rob Huffman Tue, 11/04/2008 - 10:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Vicky,
You have many options for cables and patch panels. Probably one for every situation that we can think of :) Here are the parts you would need to connect to a 24 port, rack mounted Patch Panel (without needing to terminate the cable with Bix or 110 connecting tools on terminating blocks).
Cisco RJ21 Cables
http://www.stonewallcable.com/product.asp?dept%5Fid=102&pf%5Fid=SC%2D9754
24 Port with RJ21 Male
http://www.cablingsys.com/iteminfo.asp?productcode=017-224M62U
These are just examples :) I have not checked pricing $$
Hope this helps!
Rob
