Setting up an intercom with CM 5.1(2)??
Nov 4th, 2008
Does anyone have any experience with setting up an intercom between and assistant and exec? We have call manager 5.1(2).
Please let me know.
Thank you.
Rgds,
Vicky
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 11/04/2008 - 10:56
Hi Vicky,
Now because CCM 5.x does not have built-in Intercom support we will have to come up with Plan B.
On Executives phone configure a Speed Dial button that goes to a new number (we'll just say DN = 1222)
On Assistants phone create a new Line with DN = 1222
Configure 1222 to Auto Answer on Speakerphone on the Assistant phone and you are good to go :)
Exec presses Speed Dial (Text label Intercom) and it rings down to Assistant automatically just like an Intercom.
Hope this helps!
Rob
victoriabardy Tue, 11/04/2008 - 11:12
Rob, you are THE MAN!!! I am going to give this a shot.
Thank you so much again for your help!
victoriabardy Tue, 11/04/2008 - 11:29
One more question. Auto answer is not one of our available line choices in our templates. How do I make auto answer available for programming?
Rob Huffman Tue, 11/04/2008 - 12:31
Hi Vicky,
You are most welcome :) Glad to be of some assistance.
Cheers!
Rob
victoriabardy Thu, 11/06/2008 - 07:25
Hi Rob,
I have set up the workaround you suggested and it works with one exception, we can't get it to beep once before going off hook. I can get it to ring once but there is nothing in our ring selection that sounds like a beep. Is there anyway to get the phone to signal with a beep before the speaker kicks in? Under the line on device section I have selected the Beep only when the phone is active but that doesn't happen?
Any advice? Please let me know if a beep is possible.
Thank you.
