Updating IPS sensor with ASDM
Nov 4th, 2008
Can you update the IPS sensor engine to IPS-K9-6.0-5-E3.pkg using ASDM instead of the CLI.
Can you do it in the same place as the IPS signature updates? The update sensor in the IPS configuration area..
hadbou Mon, 11/10/2008 - 13:42
  • Bronze, 100 points or more
You can upgrade and downgrade the software on the sensor using IPS devicve manager.ASDM is used only for PIX/ASA or AIP SSM module of IPS. Upgrading applies a service pack, signature update, signature engine update, minor version, major version, or recovery partition file. Downgrading removes the last applied service pack or signature update from the sensor.
