What does IP Options: "Router Alert" specify?
Nov 4th, 2008
We have a client using a Tanberg video device to connect to a Polycom through our ASA.
We are seeing error messages as follows:
(IPs have been changed)
%ASA-6-106012: Deny IP from 192.168.18.20 to 172.22.54.29, IP options: "Router Alert"
Anybody have any experience with this particular error?
Is it a false alarm? Should I (or can I)
allow this traffic from a trusted host inside our network?
Thanks for any info-
Lynne
ajagadee Tue, 11/04/2008 - 12:15
Lynne,
106012
Error Message %PIX|ASA-6-106012: Deny IP from IP_address to IP_address, IP options hex.
Explanation This is a packet integrity check message. An IP packet was seen with IP options. Because IP options are considered a security risk, the packet was discarded.
Recommended Action Contact the remote host system administrator to determine the problem. Check the local site for loose source routing or strict source routing.
http://www.cisco.com/en/US/docs/security/asa/asa70/system/message/logmsgs.html#wp1279793
Arul
*Pls rate if it helps*
frbaker07 Thu, 01/13/2011 - 09:59
Is it possible to disable the packet integrity check on
an ASA 5510 - or at least prevent the check from specific sources
- and if so, how?
I am getting these errors from our campus to campus video conferencing using Polycoms and I simply want this security check out of the picture for these connections.
Thanks, Forrest
Jay Johnston Thu, 01/13/2011 - 15:25
Forrest,
     We started seeing this problem more and more, so we changed the ASA code accordingly. Starting in version 8.2(2) the ASA gained the ability to have the configuration specify how it should treat ip options like router alert.
See the release notes for 8.2(2) here:
http://www.cisco.com/en/US/docs/security/asa/asa82/release/notes/asarn82.html#wp424893
And the configuration guide section on ip options shows how to configure the ASA:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/inspect_basic.html#wp1548725
An upgrade to version 8.2(4) would do the trick.
If you plan upgrade to version 8.3, please read and understand this document first:
https://supportforums.cisco.com/docs/DOC-12690
After the upgrade, the policy-map configuration would look like below (the new config is the 'inspect ip-options' command:
ASA# sh run policy-map
policy-map global_policy
class inspection_default
  inspect ip-options
Sincerely,
     Jay
