NETCONFIG : Update Hostname
Answered Question
Nov 4th, 2008
I would like to update the hostname on 175 devices to match the device name that displays in CiscoWorks. Is there an easy way to do this? If so, how?
Thanks!
Overall Rating: 5 (1 ratings)
drew.salmon Tue, 11/04/2008 - 17:52
Thank you Joe.
So this appears to be a static file that I would have to manually generate, like this:
68109.ROUTER
And so on, for all 175 devices I want to change?
There is not a way to declare values and call those values via a script? Or maybe something like set hostname = device name?
If not, the above method is better than logging into each device and manually setting the hostname.
Thank you!
Joe Clarke Tue, 11/04/2008 - 20:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This parameter file must be created manually. There is no existing automatic method to do this. However, you could script its creation.
