Incoming Access List blocking Outgoing Internet Access on 877W
Nov 4th, 2008
I have set up my 877w with the following config, I wanted to block incoming access to the ATM0.1 interface so created the "OUTSIDEIN" access list.
I also created the INSPECTOUT list for outgoing packet inspection (which I believed would bypass the incoming access list restriction)
When I apply the OUTSIDEIN access list to my ATM 0.1 interface internet access stops for my clients.
Any idea why this could be? or any debugs I could use to find out why?
Many Thanks, Chris
version 12.4
no service pad
hostname router
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
no aaa new-model
clock timezone gmt 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 syslog
dot11 ssid wirelessnet
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 xxxxxxxx
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.70.1
ip dhcp pool internal
network 192.168.70.0 255.255.255.0
default-router 192.168.70.1
dns-server 192.168.70.1
lease 0 2
ip cef
ip domain name router.com
ip name-server 87.x.x.x
ip inspect name INSPECTOUT tcp
ip inspect name INSPECTOUT udp
ip inspect name INSPECTOUT http
no ipv6 cef
username xxxxx privilege 15 secret 5 xxxxxxxx
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode adsl2+
interface ATM0.1 point-to-point
ip address xx.xx.xx.xx 255.255.240.0
ip access-group OUTSIDEIN in
ip nat outside
ip inspect INSPECTOUT out
ip virtual-reassembly
atm route-bridged ip
pvc 0/101
oam-pvc manage
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid wirelessnet
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 192.168.70.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.xx
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 130 interface ATM0.1 overload
ip access-list extended OUTSIDEIN
deny udp any any
deny tcp any any
deny ip any any
access-list 130 permit ip 192.168.70.0 0.0.0.255 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler max-task-time 5000
ntp server 192.43.244.18
end
shaw.chris Wed, 11/05/2008 - 03:06
Hi, does anyone have any idea what could be causing this or debugs to use? Thanks Chris
shaw.chris Sun, 11/16/2008 - 13:48
Hi, could anyone help me with this please, I still haven't been able to get this problem resolved
Thanks, Chris
remi-reszka Tue, 11/18/2008 - 18:13
Are you still having problems with your config?
I could help you but I don't wanna type here too much in case you resolved your problem.
Remi
Fernando_Meza Sun, 11/16/2008 - 22:22
Try removing the inspection from the ATM0.1 interface and place it on the BVI1 instead in the inbound direction i.e
ip inspect INSPECTOUT in
I hope it helps .. please rate helpful posts !!!
remi-reszka Tue, 11/18/2008 - 18:27
You would need to rewrite your config a little bit. First of all I would apply your inspect rule to your inside interface in "in" direction. Also create ACL to allow all ip traffic out if you wish and apply it to the inside interface also in "in" direction.
In order for CBAC feature to work you need to specify inspected traffic like tcp or udp by creating an ACL an allowing this traffic through the interface.
For the outside interface block all the traffic "in" unless you need to allow some of it and you don't need to apply the inspect rule over there unless you allow traffic through from the outside.
The traffic once allowed from inside to outside will be inspected and allowed back into inside.
Let me know if you have any more troubles.
Remi
shaw.chris Sat, 11/22/2008 - 03:39
I tried adding an access-rule to allow all traffic inward into the BVI1 interface along with the inspect rule inward into the BVI1 interface.
I also added the access-group inward to the ATM0.1 interface that blocks all traffic
Unfortunately the same issue occured and I can not access out from the LAN to the Internet
Chris
shaw.chris Wed, 11/19/2008 - 00:33
Thanks I'll give this a go,
BTW adding "ip inspect INSPECTOUT in" to the BVI interface inbound didn't work
Strange thing is, I set up another 877w which worked ok with the same inspect/ACL rules as in my config. The only difference was that it had a Dialer0 interface that I applied the rules to.
Chris
remi-reszka Wed, 11/19/2008 - 07:36
What is this interface BVI1? I didn't work with 877W series yet, soon I'll be buying one but probably 881W. I guess it's not for wireless access.
Why don't you create a VLAN interface, add certain FastEthernet to it, add inspect rule in the same direction as you apply ACL to it. Don't forget you may need to adjust mss on the inside interface. Or even work with VLAN1 and apply rules to this interface just to check whether your config works.
Let me know how it works.
Remi
shaw.chris Wed, 11/19/2008 - 07:45
BVI1 is needed to set up a Bridge in order to use both the LAN ports and WLAN
