WPA with ACS 4.2 not working
Nov 4th, 2008
I currently have 70+ AP in system, no controller and use no encryption. I want to move towards WPA or peap with the ACS as my AAA and I use microsoft AD and LDAP for user authenication. For test purposes I am using a self sign cert in the ACS. I have tha APs configured for open auth EAP, TKIP, Network EAP, keymanagement mandentory and WPA.
I have the dell wireless client set up for WPA-enterprise, PEAP and MS-Chap v2.
I constant recive the following error in the ACS External DB reports about an error condition and after several attempts Authen session timed out: Challenge not provided by client.
Scratching my head, and a little dazed and confused.
Can someone tell me what I am missing, or messed up. I have been working on this for 8 days.
Mike
michael.m.williams Wed, 11/05/2008 - 10:01
Thank for the doc, but i still couldn't get it to work here is a copy of the debug dot11 aa authenicator all.
i keep getting a authentication fail
I ran a
ITSTESTAP#test aaa group radius mike xxxxxxx legacy
Attempting authentication test to server-group radius using radius
User was successfully authenticated.
And it works. I configed Ap to use WEP open authenication, but still get a fail
Mike
Scott Fella Wed, 11/05/2008 - 12:02
What do you mean you configured the AP for WEP and it failed? You mean that you setup WEP encryption on that AP and a user configured for WEP failed?
michael.m.williams Wed, 11/05/2008 - 13:23
Sorry,
I used the Doc you sent me and started over from stracth in my AP config So I configed it for WEP encrption (open EAP, network EAP, wep key mandantory encryption key 2 (no key).
I then configed my client for peap ms-chap-2 and try to authenicate to LDAp and it failed.
After creating local user I can authicate. Getting closer.
But i can't auhtenicate with LDAP or AD account. When I do a test aaa group radius domain\username password legacy it gives me user succeffully authenicated. Any ideas?
Mike
Scott Fella Wed, 11/05/2008 - 13:25
Well your radius server is the one passign the credentials... what shows up in the radius logs.
Your encryption is WPA2/AES PEAP/MSChapv2 correct?
michael.m.williams Wed, 11/05/2008 - 14:11
In the ACS under the failed atempts report tab I have "authenication type not support by external db"
michael.m.williams Thu, 11/06/2008 - 06:52
I have a remote agent installed on one of my domain machine and configured generic LDAP and also windows dats as my external databases, I want to use WPA as my encryption. What changes ti I need make or can i make then to use the two external database and no client cert to make this work?
mike
Trending Topics - Security & Network
