job failed in RME Netconfig
Nov 4th, 2008
hi
I keep gettnig this error when I run a netconfig job (add commande) in a 3560 switch :
ERROR:RME_CDL1031:Transport session to device failed TFTP: Failed on the device. Unable to create a socket to /10.128.31.37
Anyone know what the cause of this error?
Joe Clarke Tue, 11/04/2008 - 15:41
It looks like you don't have the proper Netconfig deployment protocols selected under RME > Admin > Config Mgmt > Transport Settings. Either that, or the switch is not reachable by either telnet or SSH from the LMS server.
bdiouf99 Wed, 11/05/2008 - 06:45
hi,
i verify the netconfig deployment protocols in RME and it's OK.
i configure properly the job but i have always this error:
what the cause ?
Joe Clarke Wed, 11/05/2008 - 10:10
What is your deployment protocol order? What protocol should be used to deploy this config change?
bdiouf99 Fri, 11/07/2008 - 02:08
thank you clarke, i remover "tftp" from the list of protocol used to deploy the config by netcofig. and i use only telnet, so every thing is ok.
thank you!
