2960 uplink Giga ports Slow
Nov 4th, 2008
Dear Sir's
It is the first time I used this forum, and I wish that you can help me.
I have 2 Catalyst WS-C2960-24-TC-L and WS-C2960-48-TC-L each one of them connected to other network with SPF on one of the Giga uplink ports.
now I have one empty Giga uplink port on each one, so I connect them to 2 servers ( having giga network card inside ).
tha problem is that these 2 servers becomes very slow than connecting them to normal 100 MBPS ports.
My servers network status show 1 GBPS speed, but speed very low.
Is there is some setting for these uplink ports to have a real speed Of 1 GBPS.
Thanks in advance.
Eng. Amgad Steen
itdsmartnet Wed, 11/05/2008 - 00:48
hi,
Can you post me the the output of these ports. "sh int gi0/0 switchport."
glen.grant Sun, 11/16/2008 - 17:43
If you do a show interface status on the switches what does it show for the interface speed and duplex ? Also verify patches are good , to run gig speed you have to have a good patch that has all 8 wires , gig uses all 8 wires . Normally to run gig you just leave the ports as auto and they will negotiate gig if both sides are capable.
