SSL Certs on Standby ACE module
Answered Question
Nov 4th, 2008
hi,
I have imported the SSL keys/Certs to standby ACE module and the FT group status is now showing HOT_STANDBY instead of COLD.
However, I don't see key and cert under ssl-proxy service definition as well as the reference to ssl-proxy server in the policy map configuration on the redundant module. Is this normal ?
Would the above definitions be seen after successful failover ?
Correct Answer by Gilles Dufour about 8 years 4 months ago
the ssl-proxy config on the standby could not be applied because of missing files.
If for some reason, the standby became active, it would do a synch to the other device which would result in both ACE having the wrong config.
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 11/04/2008 - 23:51
  • Cisco Employee,
No. You should see the correct config before failover.
Make sure to run the latest version and if the problem persist open a service request with the TAC.
G.
new_networker Wed, 11/05/2008 - 01:54
It is resolved. For some reason, the SSL related configurations got wiped off from the active module and I had to redo it.
Would you know of any reason for this behaviour. Scary...
Correct Answer
Gilles Dufour Wed, 11/05/2008 - 02:44
  • Cisco Employee,
Gilles.
new_networker Fri, 11/14/2008 - 01:14
Yup. That was the reason. The failover occurred before configuration was fully synchronized.
chris.pomeroy Sat, 11/15/2008 - 09:55
If you don't have the certs on both modules, they won't sync.
Also if you see that the ft group is in cold_standby,
You can do the following to get them to sync back up.
ft group 2
no inservice
inservice
This does not cause any issues. I have had to do it serveral time.
