WebVPN user credentials passing
Nov 5th, 2008
Hi everybody,
I am using Cisco VPN 3000 Concentrator for my WebVPN users.
Is there any way to pass user credentials to my HTTP servers which require user credentials to login?
Branimir
amritpatek Tue, 11/11/2008 - 10:53
  • Silver, 250 points or more
To automatically submit the WebVPN login credentials of a particular WebVPN user to internal servers using NTLM, basic HTTP authentication or both, use the auto-signon command in username webvpn configuration mode.
The auto-signon command is a single sign-on method for WebVPN users. It passes the WebVPN login credentials (username and password) to internal servers for authentication using NTLM authentication, basic authentication, or both. Multiple auto-signon commands can be entered and are processed according to the input order (early commands take precedence).
Branimir Turk Tue, 11/11/2008 - 23:48
Thank you for the information.
But, the problem is that I cannot figure out how to enable auto-signon on Concnetrator 3000.
Becaouse on web interface there is no option to enable this feature??
