Unknown number
Nov 5th, 2008
Hi all,
i've a problem with incoming calls, when i recieve a call i see unknown number, this is my debug:
*Apr 15 23:13:52.266: %ISDN-6-DISCONNECT: Interface Serial1/0:8 disconnected from unknown , call lasted 176 seconds
*Apr 15 23:13:52.270: ISDN Se1/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x1E90
*Apr 15 23:13:52.286: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x93EE
*Apr 15 23:13:52.310: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x13EE
*Apr 15 23:13:56.822: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x13EF
Cause i = 0x8190 - Normal call clearing
how can i fix this pb, any idea will be appreciate
Med
Overall Rating: 1 (1 ratings)
mchin345 Tue, 11/11/2008 - 15:24
%ISDN-6-DISCONNECT: Interface [chars] disconnected from [chars] [chars], call lasted [int] seconds.
This is an informational message sent when a call is disconnected. This message displays the remote name and number, which it receives from the PPP authentication or from the location at which the dialer placed the call. This message also reports the duration of the call.
The reason you probably have these call disconnected is during PPP negotiation so you can monitor this by enabling the following debugs
debug ppp authentication
debug ppp negotiation
debug isdn q931
Above commands show the reason for the unknown numbers
pranabgaya Sun, 01/25/2009 - 16:03
hello, can u post the "isdn q931 debug" taken during a incoming call.
