I can't install the NPE-G2 on Cisco router 7206 VXR
Nov 5th, 2008
i'm trying to install the NPE-G2 on Cisco Router 7206VXR but the keying post on the NPE-G2 stock in the end of the chassis.
Anybody have this problem before please help ASAP
Amit Singh Wed, 11/05/2008 - 04:24
  • Cisco Employee,
Could you please capture the router booting sequesnce and paste it here.
kashalo84 Wed, 11/05/2008 - 04:42
I can't start the router because I couldn't insert the NPE-G2 into the slot because the keying post as illustrated in the attachment file. And you know the NPE-G2 is the main controller of the router.
Giuseppe Larosa Wed, 11/05/2008 - 07:28
  • Hall of Fame,
    Founding Member
Hello Anas,
are trying to insert the NPE-G2 in place of the current NPE ?
Be aware that in same side of PAs there is the I/O controller
verify that the chassis is 7206VXR and not a C7206.
boot with the old NPE and issue
show c7200
and check the chassis type
Hope to help
Giuseppe
kashalo84 Thu, 11/06/2008 - 05:09
Hello Giuseppe
thank you so much for your help.
i notice that there is two NPE-G2 version one with keying post and one without and the chassis that i have don't support the new one and i think i should get the older version of NPE-G2 i don't think that i have another choice.
