web tunneling software - how does it get past firewall
Nov 5th, 2008
hi all, if we use a ASA, application layer firewall, how does things like gotpmypc remote access software manage to tunnel through it, i would of thought the http inspection would block it,
what exactly happens ?
dhananjoy chowdhury Wed, 11/05/2008 - 21:24
  • Silver, 250 points or more
You will have to use the MPF feature on the ASA to block the GoToMyPC traffic.
Configure the policy-map type like this
policy-map type inspect http GotoMyPC_HTTP
parameters
match request uri regex _default_GoToMyPC-tunnel "machinekey"
drop-connection log
match request uri regex _default_GoToMyPC-tunnel_2 "[/\\]erc[/\\]Poll"
drop-connection log
Also refer to this document
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808c38a6.shtml
Hope this helps.
