Cisco Anyconnect VPN Client V.2.2
Nov 5th, 2008
The Anyconnect client has a Group, username and password field. Can password be modified to say Passcode. This is an issue because we use RSA passcodes as authentication. Thanks.
sadbulali Tue, 11/11/2008 - 07:23
  • Bronze, 100 points or more
When using cisco anyconnect vpn client, since it is a software the username and password filed names are hardcoded and so can not be changed.If you are using webpage to access the vpn client then the login page credentials can be changed.
