PIX 501 VPN Issue
Nov 5th, 2008
  • Silver, 250 points or more
Hi there,
We have a PIX 501 which a customers uses as a VPN end-point to RDP via the Internet to their servers on the inside of the PIX. The VPN works fine and the customer can connect to their server using RDP, however when a 2nd user connects to the same PIX via the VPN and succesfully authenticates they can't connect to the same server via RDP. The customer has the required licenses on the servers for multiple RDP connections and when we bypass the VPN all users can access the same server via mutiple session. My understanding was that the PIX 501 allows 10 concurrent VPN connections which it seems to, but i'm unsure why only one source IP address can gain access to the server on the inside of the PIX, could this be a licensing issue?
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 13-Aug-03 13:55 by morlee
UKG-Litmus-PIX up 123 days 17 hours
Hardware: PIX-501, 16 MB RAM, CPU Am5x86 133 MHz
Flash E28F640J3 @ 0x3000000, 8MB
BIOS Flash E28F640J3 @ 0xfffd8000, 128KB
0: ethernet0: address is 0009.b74a.b24b, irq 9
1: ethernet1: address is 0009.b74a.b24c, irq 10
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces: 2
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: 10
Throughput: Unlimited
IKE peers: 10
This PIX has a Restricted (R) license.
Here is a snippet of the config showing the VPN setup
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap client authentication LOCAL
crypto map mymap interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup Customer-VPN address-pool client
vpngroup Customer-VPN dns-server x.x.x.x
vpngroup Customer-VPN default-domain xx.net
vpngroup Customer-VPN split-tunnel 102
vpngroup Customer-VPN idle-time 1800
vpngroup Customer-VPN password ********
ip local pool client 192.168.2.1-192.168.2.254
access-list outside line 1 permit ip 192.168.2.0 255.255.255.0 any (hitcnt=1034)
access-list 101 permit ip any 192.168.0.0 255.255.0.0
access-list 102 permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
nat (inside) 0 access-list 101
Any ideas would be appreciated?
PJ
ajagadee Wed, 11/05/2008 - 11:35
  • Cisco Employee,
PJ,
Your configuration looks good and if it works only for one user and not the others over the IPSEC Tunnel, I would use the "Capture" command on the pix and do a debug on the packet and see what the pix is doing with the RDP Requests from the Second Client. This should point you in the right direction.
Also, to answer your question regarding licensing, one quick way to find this is to do clear the xlates on the Pix501 and have only VPN Clients connect to the Pix and try to access RDP.
Arul
*Pls rate if it helps*
