sebastiandm Wed, 11/05/2008 - 07:21
When the phone is in an unregistered state you will not be able to make incoming/outgoing calls.
Jaime Valencia Wed, 11/05/2008 - 07:40
  • Cisco Employee,
  • Hall of Fame,
    2011
exactly what you want to happen??
what behavior you want to have???
java
if this helps, please rate
goranr Wed, 11/05/2008 - 22:48
If line is active, iven if the phone is unregistered, I will be routed to that line. It is a problem. When the line is on remote site, I will stil have to configure fild under line "Unregistered internal" and "Unregistered external" and it will be OK only for one location.
Stil, I can not use abbriviated diling (4 digit preserved srst), because that 4 digit pattern will never be matched for particular phone.
Any solution for that?
