netconfig : how can i represent "Enter" key in a command
Nov 5th, 2008
i want the define a user-tasks to deploy this command:
SW_E3_IT_NAC2#copy flash:testNAC.txt startup-config
now, i want to know how represent the "Enter" key in the script to confirm the destination :
Destination filename [startup-config]?
Overall Rating: 5 (1 ratings)
dhananjoy chowdhury Wed, 11/05/2008 - 09:02
use the script lines below
Joe Clarke Wed, 11/05/2008 - 09:52
Use the notation to indicate the expected response. For example, above:
bdiouf99 Fri, 11/07/2008 - 07:34
hello clarke,
i used after each command :
erase nvram:
the switch reload, it's work fine and i got the result that i want!!
But the job result display to me "Failure", there is the message :
Deploy command partially failed Insufficient no. of interactive responses(or timeout) for command: reload. Could not synchronize RME archive with Device Config
what that means ???
Joe Clarke Fri, 11/07/2008 - 09:46
Any Netconfig job which ends in a reload will be reported as failed since the switch immediately reloads after the command, and RME cannot verify the results. This is fixed in RME 4.1 which has added a Netconfig task specifically to do a reload. If you end the job with this task, then the job will be reported as success.
