Integrating LMS Server to an ACS
Nov 5th, 2008
I want to clarify some things in respect to the above subject matter. I want to know the following:
ACS username and password. Will I use the system identity name and password which I created on the CWLMS here or will I use the ACS admin username and password.
Someone should please clarify this for me.Thanks.
mchin345 Tue, 11/11/2008 - 07:07
  • Silver, 250 points or more
You should use ACS Admin user name & password for login Cisco Secure ACS. ACS Admin Name: Enter the administrator user name that you would use to log in to Cisco Secure ACS. This is the same user you created under Administration Control in ACS.
ACS Admin Password: Enter the administrator password that you would use to log in to Cisco Secure ACS
For further information click this link.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html#wp9000205
troymaki Wed, 11/26/2008 - 14:46
Maybe this will help. I had the same question and found this today.
Add the System Identity user
The System Identity user makes possible the trusted communication between LMS and ACS servers. It must be properly set up on both the LMS and ACS servers.
First, in LMS Common Services, add the System Identity user under Local User Setup and assign it all the default roles (Figure 15).
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html#wp9000155
