Assign VLAN via DHCP
Answered Question
Nov 5th, 2008
  • Purple, 4500 points or more
Does anyone know if this can be done to a workstation? I know phones can be done through option codes, but I think those codes are vendor specific. Is there an option that anyone knows of that will assign a workstation to a vlan?
Thanks!
John
Correct Answer by dhananjoy chowdhury about 8 years 6 months ago
You need to configure dot1x authentication on the switch.
When the workstation connects to the switchport it will ask for authentication and on successfull authentication it will put in a particular vlan and on auth fail onto a different vlan.
Correct Answer by Jon Marshall about 8 years 6 months ago
John
There are 2 options that i know of
1) VMPS (Vlan Membership Policy Server) where you set up a database of workstation mac-addresses to vlan mappings. Very time consuming and i'm not aware of that many people using it. Old technology to a large extent replacd by
2) 802.1x - you can authenticate users/machines on the switches and do a dynamic vlan assignment based on their credentials. You need a AAA server and it again it is not something you configure in a couple of minutes :-)
I'm not aware of a way to do it via DHCP but others may know.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Wed, 11/05/2008 - 08:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
Jon
Correct Answer
dhananjoy chowdhury Wed, 11/05/2008 - 08:55
  • Silver, 250 points or more
