CSA 5.0 blocking IBM DSA diagnostic executable
Answered Question
Nov 5th, 2008
I need to run a diagnostic on our Unity servers.
CSA is denying it.
I have not worked with CSA much.
Do I need to disable it to allow this diagnostic to run or is there a way to grant permission or something?
Correct Answer by Tim Smith about 8 years 8 months ago
Not sure what versions you are using there.
I am assuming you are using the headless version (you dont have CSA management console and are using the standalone version)
But you can disable CSA while you do your thing.
From a VNC / KVM or directly on server - (do not do it through RDP) - It will ask you to allow the action, and possibly verify a code on the desktop itself when you stop the service.
Go to services.msc
Select the Cisco Security Agent service.
Stop it
If you will reboot as part of your work then also set it to disabled so it doesnt restart automatically.
When you are done, set it to automatic and start it again.
Cheers,
Tim
Overall Rating: 5 (1 ratings)
Correct Answer
Tim Smith Wed, 11/05/2008 - 13:25
  • Silver, 250 points or more
Go to services.msc
Stop it
Cheers,
Tim
phretbored Wed, 11/05/2008 - 15:59
Tim,
Ok cool I will try your suggestions.
We are using CSA 5.0 standalone.
I will disable CSA to get the diagnostic done then.
TAC says I should be able to run this without affecting performance and I do not believe a reboot is required for this process.
Why do you say to not use RDP?
Tim Smith Wed, 11/05/2008 - 18:39
Not sure on the IBM diags..
But disabling CSA service is definitely non-intrusive. Well unless you catch a DOS attack while its off or something :)
When CSA realises you are trying to disable it, it will prompt you on the actual console of the server... and you have to allow it.
Some versions also prompt you with a code that you have to enter back into it.
You wont see the prompt on an RDP session. So it wont actually let you stop it.
Cheers,
Tim
