CUCM 6/Unity 5.0 Call Handler taking 5-6 rings to answer
Nov 5th, 2008
I have a DID coming in on an FXO port which forwards to a CTI route point that forwards to a call handler in Unity. When the number is dialed it takes about 5 or 6 rings for the AA to answer. Is there a way to have this answer immediately?
jbarcena Wed, 11/05/2008 - 13:22
  • Red, 2250 points or more
Check the Port Status Monitor at the time of the call to see if the ports are idle or if all of them are busy. I recommend you to reset the ports in case they are hanging.
//Jorge
Tommer Catlin Wed, 11/05/2008 - 13:23
  • Green, 3000 points or more
Also check your TSP version. You may need to update it, restart Unity.
gmgarrian Wed, 11/05/2008 - 13:38
Actually, I figured it out. I had caller id configured on the FXO ports to ring 4 times.
I removed that and all is well.
