CSS Cookie load balancing
Nov 5th, 2008
I have a content rule to do weighted round robin load balancing among three web servers.
I want to be able to direct traffic to ONE of these three servers if a cookie matches a regex. If there's no match, the traffic should be balanced between the other two machines.
First: Is this possible? I'm having trouble understanding the documentation.
Second: If so, how? :)
Below are my configs. Thanks to anyone who can shove me in the right direction.
Name: www-abtest Owner: SFColo
State: Suspend Type: HTTP
Balance: Weighted Round Robin Failover: N/A
Persistence: Enabled Param-Bypass: Disabled
Session Redundancy: Disabled
IP Redundancy: Suspend
L3: 10.1.1.50
L4: TCP/80
Url:
Redirect: ""
TCP RST client if service unreachable: Disabled
Rule Services & Weights:
1: c2-cr26-www-Suspended, S-10
2: c2-cr28-www-Suspended, S-10
3: cr-cr25-www-Down, S-1
Name: c2-cr26-www Index: 61
Type: Local State: Suspended
Rule ( 192.168.1.59 TCP 80 )
Redirect Domain:
Redirect String: (null)
Keepalive: (HTTP:GET:/status 5 3 5 )
Keepalive Encryption: Disabled
Last Clearing of Stats Counters: 11/04/2008 10:59:20
Mtu: 1500 State Transitions: 1
Total Local Connections: 29 Total Backup Connections: 0
Current Local Connections: 0 Current Backup Connections: 0
Total Connections: 29 Max Connections: 65534
Total Reused Conns: 0
Weight: 10 Load: 255
Weight Reporting: None
CSS11501(config)# show service c2-cr28-www
Name: c2-cr28-www Index: 62
Rule ( 192.168.1.61 TCP 80 )
Redirect Domain:
Last Clearing of Stats Counters: 11/04/2008 10:59:16
Total Local Connections: 30 Total Backup Connections: 0
Total Connections: 30 Max Connections: 65534
Name: cr-cr25-www Index: 60
Type: Local State: Down
Rule ( 192.168.1.58 TCP 80 )
Redirect Domain:
Keepalive Hash: df6feb6cd17c2b28c0336dccc62b0bdf
Keepalive Error: Response code incorrect
Last Clearing of Stats Counters: 11/04/2008 10:59:08
Total Local Connections: 35 Total Backup Connections: 0
Total Connections: 35 Max Connections: 65534
Weight: 1 Load: 255
Gilles Dufour Thu, 11/06/2008 - 05:55
The CSS can match one cookie name + cookie value to a server.
This is possible with advanced-balance cookie function.
But if the cookie value is not exactly matching the string configured, the CSS can't link the cookie to a server.
The ACE module is able to do this.
Gilles.
