no browsing to local AP
Nov 5th, 2008
I have been asked to make some changes to a 1310 AP at a new site. When I try to browse to the device, I get the login screen, but when I put in the username and password it say :not authorized. I can telnet into it and the username and password work. Could browsing be turned off? How do you turn it back on? Is there a different level of password for browsing? Any Ideas?
jeff.kish Thu, 11/06/2008 - 07:02
  • Silver, 250 points or more
Try not entering a username and type the enable secret in for the password. It might be configured to ask for the enable secret instead of local authentication. Default enable secret is "Cisco" (note the capital C).
Once telnetted in, you can check to make sure that HTTP(S) is active by looking for the commands:
(no) ip http server
(no) ip http secure-server
These commands would be toward the end of the configuration. You can disable/enable them by typing them into the config line without the "no".
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
