CDR reports
Jaime Valencia Wed, 11/05/2008 - 15:17
  • Cisco Employee,
  • Hall of Fame,
    2011
unfortunately the options for CDR reports are limited to either CSV or for some reports PDF
java
if this helps, please rate
earias1025 Thu, 12/18/2008 - 06:48
You'll have to import the text file into excel, If you copy and paste, that will give you the same output. Go to Excel > Open > browse for the file, make sure you select "All Files" under the files type on the Open Window in order to display the text files. Once you have selected the file to open, a window will show and select comma as the deliver. I think this is what you are looking for.
