Pix 501 Remote Client VPN Problem
Nov 5th, 2008
I am attempting to setup a config on a Pix 501 with Cisco VPN Client. I can get connected (authenticated) remotely with Cisco VPN Client, however I cannot seem to get any traffic to the remote LAN. When I look at the statistics in the VPN client the Bytes received is always 0. Below is my config. Your help is greatly appreciated.
-HP
: Saved
: Written by enable_15 at 20:54:47.132 UTC Wed Nov 5 2008
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname thepix
domain-name someplacehere.net
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_outbound_nat0_acl permit ip 10.1.30.0 255.255.255.0 10.1.30.96 255.255.255.240
access-list outside_cryptomap_dyn_20 permit ip any 10.1.30.96 255.255.255.240
pager lines 24
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 216.xx.xx.x 255.255.255.252
ip address inside 10.1.30.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ubpool 10.1.30.100-10.1.30.105
pdm location 10.1.30.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 216.xx.xx.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 10.1.30.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside 10.1.30.51 \pixconfig
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication LOCAL
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup removed address-pool ubpool
vpngroup removed idle-time 1800
vpngroup removed password removed
telnet 10.1.30.0 255.255.255.0 inside
telnet timeout 5
ssh 10.1.30.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 10.1.30.2-10.1.30.254 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
username ausernamehere password xxx encrypted privilege 5
terminal width 80
Cryptochecksum:xxx
: end
Overall Rating: 5 (1 ratings)
ajagadee Wed, 11/05/2008 - 14:27
Can you remove the below statement and do the testing.
Also, it is highly recommended that you use a different range of IP Addresses for the VPN Client, that is a Pool of IP Addresses that is not part of your local subnet.
Arul
*Pls rate if it helps*
halspuppet Wed, 11/05/2008 - 15:28
I removed the statement, but still no traffic to the LAN from the remote VPN client.
I will try to create a new pool and see what happens.
Thanks for your reply.
HP.
