Speed dialing not show up on the phone
Answered Question
Nov 5th, 2008
I want to add the speed dialing on the phone. I tried to add it on CCM server and CCM user web but it's not working. Is there any setting I should configure before adding the speed dialing?
Thanks. Leo
Correct Answer by Jaime Valencia about 8 years 5 months ago
none, exactly what you did?
created a new button template with SP, configured the phone to use it and then configured SP, reset the phone???
please always include CUCM version
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 11/05/2008 - 15:34
  • Cisco Employee,
  • Hall of Fame,
    2011
java
