astanislaus Wed, 11/05/2008 - 15:56
Problem happened on Oct 30 2008 at 07:56. So ignore logs for other dates.
astanislaus Wed, 01/28/2009 - 16:39
Affected versions does show versions 12.2(18)SXF10 and some versions higher too.
Leo Laohoo Wed, 01/28/2009 - 19:04
Sound like it's CSCsc33990:
Symptoms: A supervisor engine may unexpectedly reset when the
TestSPRPInbandPing as part of the Cisco Generic Online Diagnostics (GOLD)
fails for 10 consecutive times.
The following syslog error messages are typically generated right before the
supervisor engine resets, and can also be found in the crashinfo files:
%CONST_DIAG-SP-3-HM_TEST_FAIL: Module TestSPRPInbandPing consecutive
failure count:5
%CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=10% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[4412], Rx_Rate[0]
failure count:10
netint_thr_active[0], Tx_Rate[4652], Rx_Rate[0]
%CONST_DIAG-SP-2-HM_SUP_CRSH: Supervisor crashed due to unrecoverable
errors, Reason: Failed TestSPRPInbandPing
Conditions: This symptom is observed on a Cisco Catalyst 6500 series switch
and Cisco 7600 series router that run an integrated Cisco IOS software
image. The trigger for the symptom may be possible corruption in TCAM
entries that are used to perform the TestSPRPInbandPing.
Workaround: Enter the no diagnostic crash global configuration command to
disable exceptions that are being triggered by failed diagnostic monitoring.
However, you should do this with discretion because it may also prevent the
system from taking proactive measure to mitigate problems that could impact
user traffic.
Further Information: The fix for this caveat is more of an enhancement
because it only prevents the system from being over-aggressive in taking
exceptions when the TestSPRPInbandPing fails under specific conditions.
Therefore, the fix for this caveat does not address all triggers that may
cause the TestSPRPInbandPing to fail. Please consult Cisco TAC for further
assistance if you experience the same problem after upgrading to a Cisco IOS
software image that contains the fix for this caveat.
