L2L VPN Tunnel
Nov 5th, 2008
Good day all,
As of now, Main office ASA5550 and branch office ASA5510 L2L VPN Tunnel is working (both peers are Public IP). In addition to that I want to create another tunnel from branch office 1841 (which IP address is Private) to mainoffice ASA5550. Kindly advice me to configure in ASA5550, without interrupt the first tunnel.
thanks & regards,
1841-configuration
Building configuration...
Current configuration : 2638 bytes
version 12.4
hostname VPNTest
boot-start-marker
boot-end-marker
no logging buffered
enable password cisco
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp pool branch
network 192.168.1.0 255.255.255.0
dns-server 10.140.15.3 10.140.15.4
default-router 192.168.1.1
ip dhcp-server 192.168.1.1
chat-script rock"" "atdt*99#" TIMEOUT 180 "CONNECT
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key 12345 address 195.18.16.1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to195.18.16.1
set peer 195.18.16.1
set transform-set ESP-3DES-SHA
match address 100
interface FastEthernet0/0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Cellular0/1/0
no ip address
ip nat outside
encapsulation ppp
dialer in-band
dialer pool-member 1
dialer-group 1
async mode interactive
ppp authentication chap optional
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string rock
dialer persistent delay initial 5
dialer-group 1
no peer default ip address
ppp chap hostname yourname
ppp chap password 0 xxx
ppp ipcp dns request
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface Dialer1 overload
access-list 1 remark SDM_ACL Category=16
access-list 1 permit any
access-list 100 remark SDM_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 192.168.1.0 0.0.0.255 193.188.163.0 0.0.0.255
access-list 101 remark SDM_ACL Category=2
access-list 101 remark IPSec Rule
access-list 101 deny ip 192.168.1.0 0.0.0.255 193.188.163.0 0.0.0.255
access-list 101 permit ip any any
dialer-list 1 protocol ip list 1
route-map SDM_RMAP_1 permit 1
match ip address 101
control-plane
line con 0
logging synchronous
line aux 0
line 0/1/0
exec-timeout 0 0
script dialer rock
login
modem InOut
no exec
speed 384000
line vty 0 4
logging synchronous
login
line vty 5 15
logging synchronous
login
scheduler allocate 20000 1000
webvpn cef
end
smahbub Tue, 11/11/2008 - 07:12
  • Silver, 250 points or more
Two commands are used in order to allow the communication between the VPN networks and identify the traffic that should be tunneled or encrypted. This enables you to have access to the internet without having to send that traffic through the VPN tunnel. In order to configure these two options, issue the split-tunnel and same-security-traffic commands.Two tunnels can be configured between branch office and main office.
Look at the following url for the steps required to add a new VPN tunnel or a remote access VPN to a L2L VPN configuration that already exists:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807f9a89.shtml
