problem with the show runn
Nov 5th, 2008
hi .. i have a 3560 switch and all port are configured as access mode except the gig port is configured as trunk
now when i do show runn i see new commands on the fastethernet ports
like
switch port mode trunk
my ios image is
c3560-ipbasek9-mz.122-46.SE.bin
any 1 have a solution for this ??
regards
lffrwatson Thu, 11/06/2008 - 07:19
put the ports in Access mode and access vlans.
switchport mode access
switchport access vlan xxx
John Blakley Thu, 11/06/2008 - 08:00
  • Purple, 4500 points or more
Does your gig port lead to a router or another switch? Don't randomly put your ports in access mode if you don't know what they're connecting to.
--John
serenity001 Sat, 11/08/2008 - 22:53
thx ppl
i have attached two files ,
first i have erased all the config then do multiple show runn please see how new thing is coming under random ports (the file is befor config)
thin i configuerd the switch with some vlans and connect it to another switch on port f0/24
i can ping and telnet, i meant the switch is working .. but didn't get why this commands are coming
