Restricting channels for incoming calls on E1 PRI.
Nov 5th, 2008
Is it possille to restrict some channels for incoming voice calls by doing configuration on voice gateway, and the rest for outgoing calls.
What I am looking for is if I have two hunting numbers say 1234, and 5678 by Telco tied to the same line. Then the calls for these should land only on the 5 channels restricted for inbound calls.
If yes how.
Does the Telco also needs to do anything on their side.
Tim Smith Thu, 11/06/2008 - 02:30
Im not sure I catch your drift exactly.
Typically though, you can ask your telco to configure their side with inbound and outbound channels.
i.e. 5 in 25 out etc.
