Callmanager SRST with H323 gateway issue.
Nov 6th, 2008
I am trying to set up SRST with callmanager and a h323 gateway (not an MGCP gateway)
I can get it to fail over, but I am unable to retain the extension number, so the phone registers but is unusable.
pls see parts of config,
application
global
service alternate default
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.1.1.1 port 2000
max-ephones 30
max-dn 30
system message primary Operating in Backup Mode
dialplan-pattern 1 565656 extension-length 4 extension-pattern 1220
dialplan-pattern 2 54321. extension-length 4 extension-pattern 140.
dialplan-pattern 3 54322. extension-length 4 extension-pattern 141.
am I missing anything here?
Norm.
wbarren Thu, 11/06/2008 - 08:47
Are you prebuilding your ephones and ephone-dn's in your config? If not you have to set the srst mode auto-provision mode under you telephony service
all SRST mode ON (include both learned DNs and phones into show running)
dn SRST mode ON (include only learned DNs into show running)
none SRST mode ON (include NONE of the learned DNs/ephones into show running)
