11-06-2008 12:50 AM - edited 03-06-2019 02:20 AM
Hi all,
Well I am trying to configure ip slb feature on my 6500 series Switch. I have done following configuration on my switch.
ip slb serverfarm TEST
real 172.16.1.215
inservice
real 172.16.1.237
inservice
ip slb vserver VERIFY_TEST
virtual 172.16.10.150 tcp 0
serverfarm TEST
sticky 60
inservice
exit
int Vlan10
ip add 172.16.10.252 255.255.255.0
exit
My servers are in vlan 1 and my clients are vlan 10. I am having 2 servers, on which I have configured 1.235 and 1.237. both the ports are in vlan 1, and virtual ip is of vlan 10.
I want to use Server Load balancing feature for http and other features.
Please help me on this.
Thanking you.
regards,
Mangesh.
11-06-2008 01:53 AM
Hello Mangesh,
the following doc can be helpful:
Hope to help
Giuseppe
11-06-2008 02:13 AM
Hi Giuseppe,
I have followed the same document but it's not working. The request reaching till my Switch after that nothing happening.
On real servers it shows me the status goes from failed to testing and then ready for test states. And then fall back to Failed.
6506_SW2#sh ip slb conn
vserver prot client real state nat
VERIFY_TEST TCP 172.16.10.72:1646 172.16.1.215 SYNCLIENT none
And then it goes to Closing state. Can you please help me with Server end configuration also.
And also if there is any correctin required in my Switch configuration.
Thanks and Regards,
MAngesh.
11-06-2008 03:44 AM
Mangesh
What are you trying to load-balance. Is it http ?
Whatever it is can you from a client connect to the real address (NOT the VIP) and see if that works. If that does work then we can concentrate on the SLB side, if it doesn't it could be something wrong with your servers.
Jon
11-06-2008 04:35 AM
Hi Jon,
Yes I can ping, telnet to my servers directly.
I am trying right now http application.
Please help me out......
Thanks and regards,
Mangesh.
11-06-2008 04:56 AM
Mangesh
What are you load-balancing - sounds like http. You have to try accessing real servers on whatever port you are trying to load-balance on so if it is http then you need to try and connect using http - ping and telnet don't really tell us anything.
Jon
11-06-2008 05:33 AM
Hello Mangesh,
try to telnet to tcp port 80 to verify HTTP service is running on real servers
from a PC shell
telnet ipaddress port#
Hope to help
Giuseppe
11-06-2008 06:00 AM
Giuseppe
Agreed this is a useful premliminary test but Mangesh needs to actually try and bring a page up based on the real IP address unless of course he telnets and then uses the correct http get request syntax :-)
Jon
