Guest Access Unreliable?
Nov 6th, 2008
Hi All,
Has anyone experienced intermittent problems with Wireless and Wired Guest Access? The symptoms I'm seeing are the clients not being redirected to the login page and/or no IP address on the client but the client says connected ok after a repair of the connection. The only way I can get it to work again is to reboot the Anchor and Local controllers.
I'm running WCS 5.0.56.0 and WLC 5.0.148.0.
Is there anyway to fine tune the config to make it more reliable?
Thanks Folks
Scott
dinger76 Thu, 11/06/2008 - 06:42
I'm having the same problem for my wired guest access using one controller. I'm running 5.1.151.0 code. It seems to be less of a problem with Firefox.
dagyb Tue, 11/11/2008 - 11:15
I had the same problem; it turns out, that one controller was configured correctly and one was not. Depending on which Ap you were on and which controller it was connected to, it may or may not work, a reboot made it look like it fixed the problem because all of the AP's would switch to the controller that was configured corectly. You need to make sure that you have the controlers anchor paths up
Mobility Anchors
WLAN SSID
Switch IP Address (Anchor) Data Path UP Control Path UP
Switch IP Address (Anchor) 167.161.114.250(local)
Trending Topics - Security & Network
