PKI Certificate
Nov 6th, 2008
I have defined a PKI trustpoint on 871 but whilst authentication CA i get the following error:
Nov 6 10:57:05.370: CRYPTO_PKI: Sending CA Certificate Request:
GET /certsrv/mscep/mscep.dll/pkiclient.exe?operation=GetCACert&message=Synergy-CA HTTP/1.0
User-Agent: Mozilla/4.0 (compatible; MSIE 5.0; Cisco PKI)
Nov 6 10:57:05.370: CRYPTO_PKI: locked trustpoint Synergy-CA, refcount is 1
Nov 6 10:57:05.386: CRYPTO_PKI: http connection opened
Nov 6 10:57:05.386: CRYPTO_PKI: unlocked trustpoint Synergy-CA, refcount is 0
Nov 6 10:57:05.386: CRYPTO_PKI: locked trustpoint Synergy-CA, refcount is 1
Nov 6 10:57:05.598: CRYPTO_PKI: unlocked trustpoint Synergy-CA, refcount is 0
Nov 6 10:57:05.598: CRYPTO_PKI: HTTP response header:
HTTP/1.1 200 OK
Content-Length: 4274
Content-Type: application/x-x509-ca-ra-cert
Server: Microsoft-IIS/7.0
Date: Thu, 06 Nov 2008 10:56:47 GMT
Connection: close
Content-Type indicates we have received CA and RA certificates.
Nov 6 10:57:05.598: CRYPTO_PKI:crypto_process_ca_ra_cert(trustpoint=Synergy-CA)
Nov 6 10:57:05.602: crypto_certc_pkcs7_extract_certs_and_crls failed (1795):
Nov 6 10:57:05.602: CRYPTO_PKI:crypto_pkcs7_extract_ca_cert returned 1795
Nov 6 10:57:05.602: CRYPTO_PKI: Unable to read CA/RA certificates.
Nov 6 10:57:05.602: %PKI-3-GETCARACERT: Failed to receive RA/CA certificates.
Nov 6 10:57:05.602: CRYPTO_PKI: transaction GetCACert completed
My router config for trustpoint is as following:
crypto pki trustpoint Synergy-CA
enrollment mode ra
enrollment url http://ca_2008.sfs.com:80/certsrv/mscep/mscep.dll
subject-name cn=Authenticator-871 o=SFS
revocation-check none
ocsp url http://ca_2008.sfs.com/ocsp
rsakeypair Synergy
Anonymous (not verified) Wed, 11/12/2008 - 07:45
The explanation for "PKI-3-GETCARACERT: Failed to receive RA/CA certificates" is that PKI certificate has encountered failure when parsing and processing CA/RA certificates.Recommended Action is to check the status, contact the CA administrator.Also you can check whether the certification is valid or not.
This url explains about certificate authentication in detail:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080930f21.shtml#step3
synbureau Wed, 11/12/2008 - 08:05
Thank you for the reply, I got through that stage and now stuck with decoding of reply sent by OCSP (MS server 2008). the no-revocation check OID has a zero length value where as NULL is expected by cisco. MS has identified it as a bug but will be releasing its fix in SP2, just wanted to know if cisco has found a way around.
