Control Plane Policing
rsgamage1
Level 3
Level 3
How beneficial is CoPP in the context of device hardening?
What are the drawbacks of applying CoPP on an Internet Border Gateway.
Is CoPP approach analogous to IPTABLES INPUT/OUTPUT chains?
Thanks for your thoughts.
5 Replies 5
Collin Clark
I never really thought of it as hardening, but now that you brought it up, it certainly makes sense that it is. I think it's pretty important, especially in places where you can't get console access.
I don't think anything...
No. CoPP is QoS on the control plane (ie Telnet/SSH, ICMP, SNMP, IGP).
Here's a good link I found on CoPP. If you need a real world config of CoPP check the second link.
http://www.cisco.com/web/about/security/intelligence/coppwp_gs.html
http://tinyurl.com/5cmp2y
Hope that helps.
What about the router resource utilization (CPU,etc)? Could there be any performance hits once CoPP is enabled?
Negligible. It, like QoS on the data plane, is only enacted during congestion.
Hi Collin,
Have you deployed this already?
Based on your experience, any particular points one may have to focus on during implementation?
Many Thanks,
Yes I've deployed it. Be sure to test in the lab and make sure you get the protocols you need implemented. Unfortunately it's one of things you hope is configured correctly when things go wrong.
