ASA5520 set Router ID manually
Answered Question
Nov 6th, 2008
I'm configuring an ASA5520.
Is it possible to give the ASA a router id manually? If yes, whats the command for?
It should not use the highest ip address.
thanks and greetings lydia
Correct Answer by ajagadee about 8 years 7 months ago
"router-id 1.1.1.1".
router ospf 100
router-id 1.1.1.1
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/qr_72.html#wp1655194
Arul
*Pls rate if it helps*
Correct Answer by Jon Marshall about 8 years 7 months ago
Overall Rating: 5 (2 ratings)
