CRS 5.0 event viewer error
Nov 6th, 2008
I am getting the following error every 15 minutes in the event viewer on my ipccx server. crs version: 5.0(1)_Build433
thanks!
Event Type: Error
Event Source: Cisco Desktop VoIP Monitor Service
Event Category: None
Event ID: 4
Date: 11/6/2008
Time: 9:42:59 AM
User: N/A
Computer: NSPI-IPCC
Description:
The description for Event ID ( 4 ) in Source ( Cisco Desktop VoIP Monitor Service ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: FCVMS0007 Unable to open the NIC adapter [\] for sniffing.
Overall Rating: 3 (1 ratings)
ivillegas Wed, 11/12/2008 - 08:55
Unable to open the NIC adapter [\] for sniffing indicates that it didn't know which NIC to begin listening on.
On the CRS server, go to C:\Program Files\cisco\desktop\bin and launch
PostInstall.exe. Click OK to confirm the IP Address appears correctly, and another window will appear. Under VoIP Network Device, there's a drop down where you should see the NICs on the server. Is the active
NIC being used for monitoring and recording selected?
