No ASR or TTS - how to play account balance?
Answered Question
Nov 6th, 2008
I'm not very strong in java -
I have a script (IPIVR 4.0)that I need to read back an account balance, and the client has no ASR or TTS. We have recorded individual .wav files (0-99, hundred, thousand, dollar, cents, and)
How can I play back "one thousand two hundred thirty four dollars and 56 cents" from a string value equal to "000001234.56"
This has become a gigantic headache for me, since I can't figure it out on my own.
Correct Answer by Clifford McGlamry about 8 years 6 months ago
Not as hard as you might think.
Use the Create Generated Prompt step. For the Genreator type, select Currency. Set the Constructor type to (Amount, Colloquiel).
If you play with it a little bit, you'll find that this can do most of your heavy lifting for you. Check the on line documentation for details on all this.
Cliff
Overall Rating: 5 (1 ratings)
mikram Thu, 11/06/2008 - 08:04
  • Bronze, 100 points or more
You can do it with Java beans, do you have premium license installed?
ra_jeshkalra_2 Mon, 11/09/2009 - 18:06
I have doen this successfully by using CRs function create conditional prompt.
Make sure you are installed with the updated IVR patches on the IVR server.
Correct Answer
Clifford McGlamry Thu, 11/06/2008 - 13:03
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
Cliff
Anthony Holloway Thu, 11/06/2008 - 16:11
  • Purple, 4500 points or more
Alternatively, you could do this.
Say your account balance was a string stored in a variable called: accountBalance.
On the play prompt step use $[accountBalance] as the prompt you wish to play.
The special $[] prompt container will not play if the $ is a part of the value.
i.e., use "13.45", and not "$13.45"
If the dollar sign is a part of your value, use this to strip it off:
$[accountBalance.replace("$", "")]
Anthony
Clifford McGlamry Thu, 11/06/2008 - 16:35
Interesting....
That works in a regular play prompt step?
Cliff
o-campbell Mon, 11/17/2008 - 10:39
Can you use this sort of prompt step to generate a spoken phrase of test. Like "Your savings account balance" The S[variablename] will read the text digits one at a time, but can you generate a phrase?
cherilynn1030 Thu, 11/06/2008 - 19:17
This is exactly what I have done! I WAS making it harder on myself.
thanks~
ra_jeshkalra_2 Sun, 11/08/2009 - 03:12
I am using Cisco IP IVR 7.0(1)_Build168 . and TTS using Create generator pormpt.
I am not are not very sure whether we installed the Thai language while installing the IVR software initially.
But I noticed that we can chose the Thai language from the list available under System->language information and unable it(see the screenhsot).
Due to this I was able to use the Thai language as L[Th], in the create generated prompt. The IVR system is able to play the numbers in thai language to the caller.
But we have noted for currency numbers like 454.29,, it is playing like four one hundred and 54 instead of four hundred and fifty four.
Any sugegstions as to how this can be fixed.
1)Assuming the Thai language was not selected from the Cisco installation CD at the time of installation, is there any need or is it possible to put the CD now and install the thai language files.
2)Is 1) really required to be done, as we are able to install the thai Language using System->Language information.
3)Why is the create generated prompt installing the amount incorrectly in Thai language.
4)I also noticed thay we are not able to play the sequence of date playback as TTS using Create Generator prompt, i.e. the system currently plays the month then the day,, we are not able to change this sequence to play day first then the month.
Any idea how to resolve the issue in 3) & 4)
