* key not recognised on conference call with CCM 612
Nov 6th, 2008
I am having an unusual problem in that when I ring into a confernce call, I am prompted to press * then enter the numbner and press * again. The * btuoon is not recognised. I have changed the DTMF relay type on the voice gateway and still no joy. Has anyone come accross these issues before. Below is my dial peer configuration
dial-peer voice 100 pots
destination-pattern 9T
translate-outgoing called 20
port 0/0/0:15
forward-digits all
dial-peer voice 2 voip
description **Subscriber**
preference 1
destination-pattern 53...
progress_ind setup enable 3
progress_ind progress enable 8
voice-class codec 1
session target ipv4:
dtmf-relay h245-signal h245-alphanumeric
no vad
Jaime Valencia Thu, 11/06/2008 - 08:43
what's the call flow on this?? because CUCM does not recognize user input if already on call. are you using unity or something else to route the call??
if this helps, please rate
Derek McCormick Thu, 11/06/2008 - 08:47
Unity is not involved here
Call flow is
IP Phone calls external conference number ==> call connects ==> user asked to enter * code *
==> When user presses the * key, it is not recognised.
Kenneth Mohammed Thu, 11/06/2008 - 08:45
Is this calling outbound from the call manager into a conference bridge somewhere?
Kenneth Mohammed Thu, 11/06/2008 - 08:50
Try entering this command on your gateway:
voice rtp send-recv
Hope that helped, if so please rate.
