3750 PoE issues when stack and RPS used
Hi guys!
I had an issue with a couple of 3750 switches connected in stackwise mode. They were providing PoE to many IP phones and Access Points. Also, they were connected to the same RPS.
I had to reboot both switches and after that the PoE of one of the switches stayed in OFF mode. I rebooted both switches one more time but PoE was still unavailable. The "show power inline" command showed status OFF for one switch (the slave). I replaced the slave switch and the issue continued. I connected the switches to a different port in the RPS and that didn't change things.
I had to disconnect the stack cable and created a trunk between both switches in order to make the PoE working again on both switches.
What could be the cause of this? The RPS? Or is there a bug maybe?
Thanks in advance for any input.
Juan
Can you post output of show version from each switch ?
Shaheen
Both switches have the same version and feature set:
FIFCOIAKSW1ADM#sh ver
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(25)SED1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 22-Nov-05 23:37 by yenanh
Image text-base: 0x00003000, data-base: 0x0119A6B0
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
FIFCOIAKSW1ADM uptime is 1 day, 20 hours, 10 minutes
System image file is "flash:/c3750-advipservicesk9-mz.122-25.SED1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-48P (PowerPC405) processor (revision K0) with 118784K/12280K bytes of memory.
Processor board ID CAT1115NKXE
Last reset from power-on
8 Virtual Ethernet interfaces
96 FastEthernet interfaces
8 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1B:90:B0:56:00
Motherboard assembly number : 73-9675-11
Power supply part number : 341-0029-05
Motherboard serial number : CAT11155U05
Power supply serial number : DTN111440Y3
Model revision number : K0
Motherboard revision number : B0
Model number : WS-C3750-48PS-S
System serial number : CAT1115NKXE
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT11155GFA
Top Assembly Part Number : 800-25858-03
Top Assembly Revision Number : J0
Version ID : V05
CLEI Code Number : COM1W00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750-48P 12.2(25)SED1 C3750-ADVIPSERVICESK
Configuration register is 0xF
I have exactly same model switches running without any problem with IPBase.
I have version 12.2(25)SEE2 on one stack
I also have another stack running version 12.2(35)SE5.
Try upgrading and see if it helps
Hope This Helps.....
Shaheen
I'll try to upgrade the IOS but I think first I'll try a different RPS. I'll let you know. Thanks a lot!
