Filtering an inbound number on a PRI
Nov 6th, 2008
Is there an easy way to filter an inbound number on a PRI. We are receiving harrassing phone calls on the three main numbers for our reception desk, and they always come from the three phone numbers the harrasser has, home, work and cell.
Running MGCP at all sites so not sure we want to switch to H.323 to try to use translation rules.
Jaime Valencia Thu, 11/06/2008 - 10:22
  • Cisco Employee,
  • Hall of Fame,
    2011
MGCP relies all call control to CUCM, CUCM does not uses ANI for routing purposes, only called number
It's H323 you need
Reject Calls
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
ask your telco if they have anything on their side to do this
java
if this helps, please rate
